Ana içeriğe geç
Digitizer replacement
I'm having terrible luck with one of these as we speak.
What is the best way to connect the cable to ensure it's properly seated?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I like to hold the LCD assembly at a 90° angle from the housing (on a table), pull the connector over the top of the frame and put the connector in it's approximate location. Look under the connector as you're lining it up to make sure it's centered. Once you get it in position, lock it in with a spudger or iPod opening tool. Make sure that the LCD flex cable is folded properly so it doesn't get pinched when you lay the screen down. Good luck
Austin
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Josh W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 201
