Ana içeriğe geç
2009 yılında piyasaya sürülen giriş seviyesi Photosmart yazıcı. Tek kullanımlık baskı kafasına sahip HP Üç Renkli mürekkep kartuşları kullanır.
will not connect to a wireless network
How do I get my wireless hp printer to connect to a wireless network?
Bu iyi bir soru mu?
Puan 5
2 Yorum
Dors ont conect
tarafından
Je ne peux imprimer pas de conception avec hp
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
try this steps click on the link below.
http://h10025.www1.hp.com/ewfrf/wc/docum...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
i will recommend to follow these steps to - make sure you have the right password of your wi -fi than go to the settings and uninstall the printer driver from the computer and download it from hp website and than install it again . check for any settings issue and you can also try to connect using WPS key for more information you can go to hp http://www8.hp.com/us/en/contact-hp/supp...and once you got it fixed restart printer and computer and print it again to make sure
Puan 2
Yorum Ekle
Make sure you install the cd correctly and if nothing remove printer from devices and printers and add a new one and have it find it on the wireless.
Puan 0
Yorum Ekle
If its easily possible then open the printer menu or follow the on booklet instruction to perform a factory reset. Once the reset is done then insert the installation disc and follow the on screen instruction which shall hopefully fix your problem. Good Luck
Puan 0
Yorum Ekle
Yanıtını ekle
Tara Clifford sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 9,234
