I have to start car from starter, what is wrong
I turn the key and it does nothing, have to start car from starter
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Angel Starr, replace the Ignition Switch. It is behind the Lock Cylinder and is accessed by removing the two steering covers, and the lower trim cover. This procedure above is for dash mounted and column mounted as well. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
most likely the contacts in behind the key have worn this is the part that has about 5 or 6 wires coming out of it. this part can be separated from the key barrel and replaced so you can use the same key
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 252
