Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
screen turns off when opened half way
the screen itself has no problems, but when i lift it open more then 90 degrees it will turn off. sometimes i can get it to stay on if i wiggle the screen back and forth a hundred times. is this a hinge, or a switch that can be replaced or cleaned?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This sounds like a faulty inverter cable, which is fairly common with MacBooks. Relatively inexpensive, but somewhat difficult fix.
There is a guide already on iFixit - Inverter Cable Replacement
The replacement cable is about $20 through iFixit - Replacement Inverter Cable
A note with the cable... I would remove the MacBook's top case & look at the end of the inverter cable that connects to the logic board before ordering, just to ensure you order the proper cable. There are two options and I don't entirely trust how iFixit is differentiating the two. I've seen hundreds of the Santa Rose / Penryn model connections but only a handful of the Core Duo / Core 2 Duo connections.
Hope that helps!
Connects the logic board to the display inverter. Görseli
Ürün
MacBook (Core Duo/Core 2 Duo) Inverter Cable
$19.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
i would think its a cable that is loose or is beeing squished thats y when you move the screen it turns off, check youtube for step by step guide to remove the screen on the model of your laptop or get it from here thats what i would do
Puan 1
Yorum Ekle
Yanıtını ekle
eric sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 1,640
