Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Soru Tümünü görüntüle
Soru Kapandı
Is 70% Isopropyl alcohol ok to clean an iPhone 3GS?
I was caught in a heavy rainstorm about 3 days ago and my iPhone died on me. I opened it up when I got home and dried off the components with a soft cloth as well as ordered a new LCD & Digitizer and installed those.
The screen works as it should but the backlight is still inactive.
My question is: Is 70% isopropyl alcohol enough to clean the logic board and connectors of the 3GS? I was planning on following the guide posted on this website inorder to do the fix but was just wondering if 70% was too little of an alcohol concentration.
Thank you for any help you may be able to provide.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
No. 70% isopropyl is 30 % water. Use methanol.
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
So if I were to soak or brush the contacts with it it would just ruin the phone further? Also, would 90% or 99% be the right choice then?
tarafından
90% + should be fine.
tarafından
And 90%+ is available at places such as Target or Walmart correct?
tarafından
Andrew Novotny, I get my stash of 99% through my local pharmacist. The larger retail stores are not really good in getting those items, not a big selling item for the.
tarafından
I don't know, I use Methanol. Call them.
tarafından
1 tane daha yorum göster
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 1,702
