Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
Why is my iPod touch screen unresponsive after replacement?
I have spent last night replacing my screen after I dropped it. When I finally finished, It worked fine but I didn't put it all back together. After doing so, it still worked but I hadn't put adhesive on yet. I went to sleep and when I woke up today, it worked fine until I moved the screen about 3/4 an inch. I think it might be the black digitizer cable that is causing problems. I took it apart, double checked, triple checked, and checked again that I didn't tear any wires. I don't know what else to do. I even restarted it. Is there some sort of software that will let me use my iPod Touch without actually having to install it on the iPod? (Meaning everything is done on my computer) The iDevice is also jailbroken.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
These digitizers are very, very fragile.. Plus, when you install the ipod 4 digi, you should rewrap the connector with the copper tape that was originally on the connector and wrapped around to the front of the logic board. I know that the stickum was probably bad, so what I do is use a small piece of double-sided 3m tape to reattach it.
If the connector is not taped in place properly, even moving the screen a bit could be enough to dislodge it. Sorry to say, but if I had to guess you are going to have to take it apart and double-check the digi to mb connection, and make sure it is tight.. If all this is done, then there is a possibility that you might have flexed the cable to the point to where it came loose at either end of the connections, and ruined it., Hope this is not the case, but I have done it more than once..
With all the ipods and iphones, handling the digitizer is extremely tedious and the more you handle them outside the case, the more likely you are to break something. These connectors and cables are not engineered for repeated maintenance. That is, they are set to work and stay where they are for the life of the product...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 4,254
