Ana içeriğe geç
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
driver headlight is dim
i have a problem with my driverside headlight.my daytime lights work until i put my switch on then my driver headlight is dim, when i turn my lights off my daytimes dont work and my headlight indicator light blinks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
andre, check your light bulb to make sure that you have the right one installed. Check your wiring harness for a short. Check your connectors as well as relays for corrosion and make sure that you have proper ground connection.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
1st Step:
Test with an Instrument (Voltmeter),
if the correct or sufficient Voltage is supplied at the Bulb.
Measure at the 2 terminals of the bulb.
If your vehicle has a 12 Volt Electrical System, (DC)
the display at the Test-Instrument should read approximately 12 Volts.
Most "Multi-Meters" are able to measure DC-Voltages.
(Keep well and be kind to each other)
Klaus
tarafından
Often the cause is a bad connection at the bulb-connection.
A bad connection is a Resistance for the electrical current.
This causes a Voltage-drop
and the bulb has insufficient voltage to light up fully.
tarafından
Yorum Ekle
Yanıtını ekle
andre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,490
