Waterdamage, cleaned the board not switching on
got bberry 9900,and is water damage,i cleaned the board inside with each every thinner,i.e alcohol and this and that but not switching on..plz help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Cleaning the board is not a 100% guaranteed way to fix water damage. Some times, under certain conditions, the water can cause shorts in the circuitry that cause components to fail. In some cases, it is simple an issue of corrosion on the bard, which can be repaired by cleaning the board, other times you will need a specialist to preform component level repairs. Did you only clean the main board. You may also need to clean some connectors and button pads on the inside of the phone. Corrosion can happen to any art of the phone that could have current running through it. I would go through and look for hard to see areas of corrosion and try to clean those off the see if that helps.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,123
