Ana içeriğe geç
The Samsung Epic 4G is the first US released version of Samsung's Galaxy S II. Also known as the Samsung Galaxy S II Epic 4G Touch.
16 Soru Tümünü görüntüle
How to Remove usb port because of damaged pin and solder new one
I need help in de soldering and placing my new replacement ..I can't seem to find help on this topic i dont want to buy the whole cable with usb port i wanna solder a new one in
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
7 Yorum
will, what exactly is it that you are looking for? How to dismantle? where to find the part? How to solder it on?
tarafından
how to dismantle the usb charger part correctly and install it correctly I already bought all the parts I need ..Bought a 5 pack of USB ports
tarafından
Already have a soldering iron and the tools to take apart the phone
tarafından
Thank you buddy... needed to know those easy details you just mentioned :) will report once I get this done
tarafından
best of luck to you:)
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
will, I suggest you use this teardown to disassemble your phone. It is not a guide, but does give you a general idea on how to get it accomplished. Remove the logic board. Desolder the data connections from the micro USB port on the front. Desolder the four points that hold the port to the logic board from the back. Remove the port and replace with a new one, available at places like this. Reassemble your phone. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
My question is after unsoldering the four points, are the data connectors solder as well or no? i am also doing the same operation.
tarafından
Yes they are.
tarafından
so then i would also have to unsolder the data connectors?
tarafından
Yes.........
tarafından
Yorum Ekle
One quick Q... which are the data pins that are for the ground from left to right?
Puan 0
Yorum Ekle
Yanıtını ekle
will sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 6,633
