1 GB of RAM and only 2 slot
I have only two slot and each one have 0,5 GB of RAM. I want to increase the RAM what I should do? Are there only dome kind of RAM compatible with the PC or I only have to use two RAM of the same type?
thanks you!
Bu iyi bir soru mu?
4 Yorum
Giovanni Riva here are the memory specs for your motherboard :2 * 184-pin DDR2 DIMM slots – Dual Channel DDR2 533/400 non-ECC , un-buffered memory (Max 2GB)
oldturkey03 tarafından
If in the shop I say as you said, the shop assistant will understand. Right? Becouse I don't understand any word between "motherboard" and "max "GB". :D However Thanks you again!
Giovanni tarafından
I am sorry about that. I should have asked if you understood what I said. Yes, any good repair shop should know which memory you need. Your motherboard only supports 2 GB memory. You will need 2x1GB memory modules.You would need something like this http://www.archmemory.com/ram.cfm/Packar... Hope this helps, good luck
Google translation:
Mi dispiace per questo. Avrei dovuto chiedere se hai capito quello che ho detto. Sì, qualsiasi negozio buono stato di manutenzione deve sapere quale memoria avete bisogno. La scheda madre supporta solo 2 GB di memoria. Avrete bisogno di moduli di memoria 2x1GB. Si avrebbe bisogno di qualcosa come questo http://www.archmemory.com/ram.cfm/Packar... Spero che questo aiuti, buona fortuna.
Thanks you! I didn't understand the technical specifications. :( But the important thing is that the dealer know what it means. :) (And yes, google translation work good enough, only the tenses are a little bit confused) Thanks you again, as always your help is so much useful!!!
Giovanni tarafından
