Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Soru Kapandı
Sleep/wake button and digitizer not working after screen replacement
Ok folks, this is an iPhone 4S working on AT&T. Screen cracked. Bought a replacement, this one:
http://www.amazon.com/gp/product/B0068PR...
Replacement was uneventful (I've done it about 6 times in the past), used ifixit directions. No problems during repair from what I could tell.
When I get it all back together, I notice that 1) the sleep/wake button does nothing and 2) the digitizer doesn't work (i.e., the screen turns on fine with home button, but there's no touch response whatsoever).
I've tried restore via iTunes, seemed to work normally, but no change afterward. Running latest OS (6.1.2 is it?). Can't do a hard reset without a sleep/wake button.
Any help would be greatly appreciated! Thank you!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
As I see it three things could have happened:
1) You've damaged the power button flex cable. (Most likely)
2) The flex cable isn't properly connected.
3) You've damaged the logic board. (Let's hope not)
As for the digitizer, the digitizer flex cable has probably been damaged during install or you've received it faulty.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
+ I'd go with "you've received it faulty"
tarafından
Just wanted to bring some closure to this: I opened up the phone and realized that I had indeed ripped the digitizer ribbon. And the reason the power button wasn't working is that I hadn't connected the power button cable. Duh! Thanks for your help!
tarafından
Yorum Ekle
Here's a photo of the ripped digitizer ribbon cable. When they say to be careful, they aren't joking! :-)
Thanks again.
Puan 0
1 Yorum:
You're very welcome :)
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,420
