Ana içeriğe geç
Dahili Beats Audio™ özelliği; müzikleriniz, videolarınız ve oyunlarınız için tavizsiz, stüdyo kalitesinde ses sunar. Çift çekirdekli gücü, parlak ve net dört inçlik ekranı ve sınıfının lideri kamerasıyla aynı zamanda güçlü ve çok yönlü bir performans sergiler.
Cracked touch screen panel
Resim
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
Resim
Bu iyi bir soru mu?
Puan 1
5 Yorum
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
tarafından
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
tarafından
Display and touch is damaged
tarafından
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
tarafından
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
tarafından
Yorum Ekle
En Yararlı Yanıt
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
Puan 1
1 Yorum:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
tarafından
Yorum Ekle
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
Puan 0
Yorum Ekle
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
Puan 0
1 Yorum:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
tarafından
Yorum Ekle
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
Puan 0
Yorum Ekle
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
Puan 0
1 Yorum:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
tarafından
Yorum Ekle
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
Puan 0
1 Yorum:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
tarafından
Yorum Ekle
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
Puan 0
Yorum Ekle
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
Puan 0
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 24,632
