Ana içeriğe geç
The Canon Powershot SD790 IS is a compact 10.0 megapixel digital still camera with built-in flash and a 3x Optical Zoom. It was released on March 2008.
Card is locked. Help on holidays.
I used the camera yesterday and had no problems. Went to use it today and it says card is locked.
Bu iyi bir soru mu?
Puan -1
2 Yorum
Did you check to see if it is locked?
tarafından
How do I know if its locked. Its my daughter in laws camera.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Debbie, check the slide switch on the memory card. Make sure it is not in the locked position. If that does not correct anything, check on here and see if any of those fixes are working for you. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks for the help. That`s what the problem was. I would have never have thought to look at that piece. Thanks again for the help.
tarafından
You are welcome:-) glad I could help.
tarafından
Yorum Ekle
Yanıtını ekle
Debbie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 13
Her zaman: 422
