Ana içeriğe geç
1.4GHz (or 2.1GHz) Processor, 2GB (or 4GB) RAM, 128 GB memory, 13.4" display
10 Soru Tümünü görüntüle
Soru Kapandı
How do I replace the motherboard?
Hey guys, I was just wondering how I would be able to replace the motherboard on my Adamo 13? I can take it apart fine, and I can take the motherboard out without a problem, but I can't seem to get the most important cable back in, which is the one that I imagine would be the power control board cable (It's on the underside of the board next to the video cable.) So anyway, I just wanted to know if anyone has a video, picture, or just a tip on replacing the cable without damaging anything? Thanks guys!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Connecting the power board small ribbon to the motherboard is the problem. If your remove the magnetically attached cover at the back behind the screen you can then remove the screws that hold on the screen clutch cover, once that is removed you can get at the ribbon socket and secure the connection. It's all about access!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I love you! Haha Thanks for the answer!
tarafından
Yorum Ekle
Here is a link for replacing the motherboard. Good luck.
http://www.laptopinventory.com/LaptopInv...
Puan 1
2 Yorum:
Sadly, this is a general video which I've stumbled upon many times, but thanks anyway!
tarafından
Advertisement to sell parts, this is not for a Adamo 13 it is a generic video, no help at all.
tarafından
Yorum Ekle
Szymon, take a look at the teardown right here ans see if that helps you out.
Puan 0
Yorum Ekle
It can be an exhaustive task but if you are not confident about you technical skills then try not to attempt it or alternately you can take it some local hardware shop paying few buks and get it replaced. If you want to do it by yourself then find some online tutorials on YouTube then follow the step by step instruction.
Puan 0
1 Yorum:
@david chase , so how does the OP do it?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 613
