Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3260 Soru Tümünü görüntüle
dealing with stripped female connector.
in reinstalling the main board on an iPhone 4, I stripped the thread hole while trying to get the screw to catch. I'd like not to have to replace the main board. any help is appreciated.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi jay,
I suppose this particular screw also serves as an electric connection between the thread hole and the motherboard... Here is what you could do:
Take a strip of aluminum foil (according to the length of the screw) and wind it around the thread of the screw. You might wind it even two times, depending on the diameter of the thread hole and how strong it is worn out. Press on this aluminum foil to the screw so that it really gets into the thread of the screw and "sticks on" to it. Then screw it into the hole. It should now hold the motherboard.
If necessary, and when the screw is back in the hole, you might slightly fix it with superglue at one place (dotted), so that it can't move again.
Steffen
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
thanks for you quick solution. it works.
tarafından
Yorum Ekle
Yanıtını ekle
jay vincennrs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 119
