Ana içeriğe geç
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
209 Soru Tümünü görüntüle
Wifi/Bluetooth unable to turn on, possible broadcom chip damage?
Hi!
A few weeks ago I dropped my Verizon Note 2 SCH-i605 and smashed the screen, requiring replacement of the display. I brought it to a local repair shop, and received it yesterday.
The screen works, but now the wifi/bluetooth functions will not turn on when I press them. They will both slide to "on," and after about six seconds will slide to "off." I don't get any message about activity or errors, they just slide to "off."
I hypothesize that the broadcom BCM4334 wifi/bluetooth chip has been damaged in some way (or removed), so it won't work, period. I opened up the phone and took two pics of the motherboard's sides.
My questions: What does the BCM4334 chip look like on this phone? Where is it supposed to be, so I can determine if it is still there and in one piece?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello Friend.....Myself Dipesh Patel.
The same problem was happened with my phone although my phone's model no:. is GT-N7000 but the IC for WIFI/BLUETOOTH was at the same place and of broadcom......and it is placed just upside of the battery connector,remove the silver cover from it you will see the IC......... Please If you fine the IC reply me on this number.+917405436155
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Miner has the same problem - got driven over, saved by the case for the most part.
Check out this site I found, from Samsung - wifi Bluetooth chip is 9-5. Hope that is a bit helpful.
http://global.samsungtomorrow.com/?p=290...
Puan 1
1 Yorum:
Same issue here.
little Tap/hit on a back solve the problem untill it happens again. I think this is the issue with phone hardware..
tarafından
Yorum Ekle
Yanıtını ekle
Sen Menendez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 32
Her zaman: 31,909
