Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
iPhone 4s Battery connector missing solder pad 3 pad from the left?
I have an iphone 4s and my battery connector broke while changing the screen I have soldered 3 or 4 back to the logic board. The third solder pad from the left is missing and i read that you can use a single strand cooper wire to bypass the missing solder pad. Where does the bypass wire need to go? I know it needs to go the circuits in from of the connector but which one does it need to be connected to? Sometimes the iphone will load up with the apple boot logo then restart and sometimes it will load up saying the iphone has it 100% percent and other times it will load up saying it has 2% but the fully charged plugged symbol is showing please help
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
http://cellenuity.com/wp-content/uploads...
http://www.cyberdocllc.com/new-tested-so...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
2nd pin goes to 2 places ? So 2 single strand copper wires should work
tarafından
Yorum Ekle
Courtlandt21, see if the attached image will help. No.3 wire connects to the resistor (labelled as A for you) and capacitor (labelled B for you) and you need to bridge the resistor (A)
Hope this helps, good luck.
Puan 1
1 Yorum:
hey, what if the second pad is gone
tarafından
Yorum Ekle
I know this is old but I am having the same problem, solder pads 2,3 &4 missing from the battery connector
Can you double check your post please Turkey,.. or the schematics at least, in the picture it has pin 4 going to ground but I have just got my hands on some schematics and from my understanding pin 4 goes to C294 aswell as ground
From my understanding I need to make jumpers as pictured in my upload ?
We've spoke before via email, I was asking you for advice, not really done any board work since then, this is the 1st "big job" in a long time, any help much appreciated as always
Update (06/15/2016)
forgot to put the picture in
Puan 0
Yorum Ekle
Yanıtını ekle
Courtlandt21 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 3,767
