Ana içeriğe geç
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Soru Tümünü görüntüle
Soru Kapandı
Mousepad-problem - clicks are not registered
Hello,
I have a 6 month old Late 2008 MacBook Pro 15" and about 4 months after purchase the mouse-pad developed a clicker-problem. A normal, standard (quick, not-too hard) click stopped being registered and required a much harder and somewhat lengthy click every time. Double-clicks started to be a bigger problem and general internet surfing began being annoying due to the repeated clicks required as and when I wanted to perform an action. I took the MacBook to an Apple-dealer who opened the back and apparently did something to the mouse-pad which made it function normally for a bout 3 days after which it reverted to being annoyingly difficult to use.
Has anyone out there encountered the same problem and can you help?
Many thanks in advance.
Vuk
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I know there is a screw on the opposite side of the track pad that when tightened prevents clicking. If you open up the bottom case and remove the battery it should be accessible. You'll need to use a T6 driver and all that needs to be done is to loosen it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,747
