Ana içeriğe geç
The HP Pavilion dv9000 series was introduced in 2006.
51 Soru Tümünü görüntüle
I have no sound
there is no sound coming from my computer after upgrading to windows vista
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
ABUBAKARR, check in device manager to make sure that your sound card shows up. If it worked before but stopped because of the update, get a driver for the HP that works under Vista from here. Uninstall the device, then reinstall with the new driver. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
SOLVED - I Fixed the problem, Go to Upper-Right Corner where you see those 3-Little-Dots, Click and Scroll down to "MORE TOOLS", Then Click EXTENSIONS section in pop-up next to it. Remove/Uninstall any "Audio Boosters" that you personally added AFTER you purchased it. Click on the Clock on the Lower-Right Hand Corner and LOWER your Sound, Then RELOAD Computer by Turning off/on your computer and the Sound will come back to Normal - Yay! :) :) :)
Puan 0
Yorum Ekle
Yanıtını ekle
ABUBAKARR sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 267
