Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
PS3 heatsink clamp screw broken
Hey, guys!
Short history: After more than 4 years of great service, my PS3 FAT was a bit warm and I decided to reapply the thermal paste. Everything went good, except that I broke the heatsink clamp screw.
I was just rescrewing it in place and it suddenly got a bit harder to turn. One more little turn and 'snap', it was broken, with part of it inside of its hole. So now the clamp over the Cell Chip has only one screw holding it, what is not enough to force the heatsink into contact with the Cell chip.
If you look at this picture (not from my system), the broken screw would be the lower-left one on the picture: http://guide-images.ifixit.net/igi/OLZ2u...
The result is that now the fan goes 100% within seconds after turning on the console, and the message "The system is becoming too hot blablabla" is shown without even logging in.
My question is: do you guys have any idea about what I can do to overcome this problem?
I was thinking about using something (like a thermal pad) to fill the space and force the contact. Is this a bad idea?
Thank you very much.
Bu iyi bir soru mu?
Puan -1
4 Yorum
Daniel, I think you might get a bit more of a response if you could post images to show us the damage on your board. Just knowing which screw broke is just not enough to envision the damage and may be come up with a fix. ;-)
tarafından
@oldturkey03 The thing is there is no damage on the board. The screw just broke inside its hole. That's it. Anyway, I'll try to get some pictures. Thank you!
tarafından
Did you get the broken bottom part of the screw out or is it still in?
tarafından
It is still in. I have no idea how to remove it :(
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Daniel, since the broken part of the screw is still inside the thread, you should remove this first. Get a small screw extractor and use it according the the instructions for the individual set. A set like this or this one should work. Once you remove the piece, you should check to see if it needs to be retapped. If you are not sure about doing it, check with your local vocational school or machine shop. Most of these shops will exactly know what to do. This will most certainly resolve your dilemma. It is really not a good idea to try to temporarily fix anything that has to do with the heatsink. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,197
