Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
Why home Button unresponsive after I replaced the ribbon cable?
I bought the home button ribbon cable to replace it on My itouch 4th gen. I followed the directions exactly like I was supposed to but when I turned it back on the home button sill didn't work. It clicks like it's supposed to but it is not responding. What did I do wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Maybe you've broken the ribbon cable connector, it is very VERY frail.
But before you change it, it was working sometimes or not?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
It didn't work at all. The silver button on the old ribbon cable was completely gone. It felt as if it was jammed.
tarafından
Sorry but i noticed only now that you are repairing an ipod, and not an iphone.
You may have done 2 mistake.
1-You haven't fitted fine the ribbon on the steel mid plane, or you haven't placed fine the mid plant on the ipod.
2-You have broken or you have dirtied the contact.
Maybe you could also have fitted a broken parts but it is very unsual. Unmount the device, try the button with a tester and when reassembling take more attention to put the ribbon in correct position, and clean the contact between the ribbon cable and the logic board.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 88
