Looks like the panel for the A1304 has the part number 661-5069 and is compatible with the following models:
MacBook 13.3" 1.83GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 1.83GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.0GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.13GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.16GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Late 2008
MacBook 13.3" 2.2GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.4GHz Core 2 Duo (A1181) - Early 2008 You did not quite tell us which MBA you have but it looks like this may not work for you. Information is from here
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
5 Yorum
Who is Walter Galan, why did he edit my post 3 hours ago... and what got edited???
galaxy tarafından
To find out who Walter Galan is, click on the blue name of his right after "Edited by: " To find out what was edited, click on the blue "History" tab just above and to the right of your question :-)
oldturkey03 tarafından
galaxy, powerbookmedic.com offers a compatibility chart if you know exactly which display you are looking for. I found that the best way to determine which LCD is compatible, is to go by the datasheet of the two panels. If you have the manufacturers number you can usually find the datasheet and compare the specs.
thanks guys. can you help me find an adapter? i want to connect the 13" Macbook air a1304 lcd to a 13" Macbook Air a1369. market value difference between these 2 is $200 so I am willing to put into this over $100 amd some soldering or whatever it takes jes. its gotta be possible! paypal tip for anyone that wants to walk me through it.
galaxy tarafından
galaxy, I really think you should save your money. Most people on here do not take money to help others. It's a group of people just like you, trying to help each other out. Rewards offered usually do not get anymore attention than any other question. I personally would edit that offer, however generous, out of your comment. ;-) The reward for any answer that is helpful, is a simple upvote or an acceptance if it helped. So, now where we have this out of the way, let's see what we can do to get it done. Do you have the manufacturer number on your A1369 LCD panel? If you do, please post it on here. also, post the last three digits of your serial number so we can properly identify the logic board.
