Ana içeriğe geç
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Soru Tümünü görüntüle
Hold slider no longer working
I replaced my old battery and thought I put everything back as I found it. Turns out, I messed something up with my hold switch. It's now completely loose and has lost it's functionality. I looked at some of the breakdown pictures and it looks fine, but it feels completely loose. Any ideas?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
I noticed you never got an answer to this. Are you still having this problem
tarafından
Yeah, still busted. Any ideas?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Tyler
I have a newer version, so I'm not sure, but it looks like the hold-switch is part of the headphone jack part. It can be replaced, and since you've replaced your battery, that shouldn't be a problem.
iPod 3G 10/15/20 GB Headphone Jack
(there is another part that fits 30GB version)
After taking it out, you could examine your old part to see if you can fix it, before ordering a new one.
iPod 3G 10/15/20 GB Headphone Jack Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I ordered mine on ebay, and they said that after they replaced the battery, the hold switch no longer worked. So when I got it, I opened it up. The internal part of the hold switch that connects to the button outside was connected to the logic board, and mine was broken off so there was nothing that the outside button could attach to. I am no techie, but I am pretty sure in order to replace that part, you may have to replace the logic board. Or if it is not broken, and you attempt to slide it back into place so that it can catch the hold switch, do so with caution because if it breaks clean off you will have more problems.
Puan 1
Yorum Ekle
As Sarah suggested, it could be that the actual switch is broken. If you pop the back off, can you see a little black switch near the top right corner (top right when the iPod is laying on its face)? If so, is it broken?
It could be that the little hold switch toggle itself got a bit bent out of shape; I've had that happen a couple times too. Just try to bend the pins VERY CAREFULLY back into place.
Puan 1
Yorum Ekle
Yanıtını ekle
Tyler Timpe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 1,229
