Ana içeriğe geç
Droid Razr, Motorola tarafından tasarlanan, Android tabanlı ve 4G LTE özellikli bir akıllı telefondur.
Can't get a network connection?
I am unable to access Facebook, Google, Voicemail....anything that requires a network connection. Seems like my phone is missing something it needs to connect.
Bu iyi bir soru mu?
Puan 5
1 Yorum
jamazaad9@gmail.com
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
I recommend testing your SIM card in a friend's phone to make sure that the problem isn't with the card itself, or with your account on the provider side of things. If you do this and confirm that your hardware is at fault, it will be very difficult to troubleshoot without some knowledge of electronics and antennas in general. First, check a guide to diassemble properly. This model should have a plastic antenna near the bottom of the phone, and two shiny, gold, springy contacts on the motherboard which make contact with the underside of the antenna inside the phone. Cleaning and/or resoldering usually will do the trick. This type of antenna rarely needs to be replaced because it is essentially just a piece of wire printed onto a piece of plastic. Poor connection is usually the culprit.
Also keep in mind, sometimes software glitches can result in "No Service" indications but it is uncommon in your particular model. If you can do a software update via WiFi and you have the same issue afterward, you can pretty much rule this possibility out.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Yh it is the software glitch
tarafından
Please can you help me
tarafından
Yorum Ekle
check to make sure mobile data is enabled in your settings
Puan 0
Yorum Ekle
i cant accessmobile network for calls.
Puan 0
Yorum Ekle
Well, first check your wifi settings of your phone also your router settings because what happens sometimes you get disconnected due to certain updates and have to reconnect with your wifi and if you have done these things then you can contact us personally at https://techyuga.com/kolkata/
Puan 0
Yorum Ekle
Yanıtını ekle
Kathleen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 9,121
