Ana içeriğe geç
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Soru Tümünü görüntüle
Chip burnt on the logic board, but it still works!
Recently when i was using the MacBook (Late 2011, 13', 2.4MHz i5) without it been plugged in, it turned off all of a sudden with the "chich" sound and a puff of smoke came out. I thought my Mac died. But when i turned it on, it stated to work fine (checked with diagnostics, everything worked fine).
So, Just to be sure i took it to the apple service centre, and they showed me that a chip on the logic board (below the fan) have been burnt. but the wonder is, the mac works fine. it would take me around $650+ for me to replace the logic board. can anyone please tell me if this is something i can live with and not replace the logic board ?
I have added the an image which shows the chip as i remember by the red-arrow. it will be either one of them for sure. (i dont have a pic because the macbook is with apple at the moment, trying to figure out if this is claimable by apple care)
Bu iyi bir soru mu?
Puan 1
12 Yorum
Hashan Ranatunga, add an image to your question so we can see what you see. Right now it is very difficult to determine which "chip" you are looking at :-)
tarafından
I have added the an image which shows the chip as i remember in red dots. it will be either one of them for sure. (i dont have a pic because the macbook is with apple at the moment, trying to figure out if this is claimable by apple care)
tarafından
Looks more like an isolated component than an IC. I think we'll wait till you need to know for sure. Good for you if it is covered by Apple.
tarafından
Since we don't have the schematics for your board it's hard to know the function of the faulty component but test everything that's connected near the damaged IC (optical drive, airport, backlight keyboard, etc). Also, it would be important to find the cause of the damage. Something shorted under the bottom panel, check if any screw is missing somewhere and could have shorted the board. If you're lucky the damaged component is not a critical element for the board operation and is located at the end of the circuit so it doesn't open the circuit.
tarafından
Apple didn't get back to me on if this is covered by the warantee. They gave me an indication and said that burns to the logic board are not covered by the warantee. :( which will cost me $ 650+ for a logic board replacement.
If all the features and functionality are working fine, do you think this is something I can live with ?
tarafından
7 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
thanks a lot for the comments guys. i got my MBP today from apple care and they have replaced the logic board. i asked them what have gone wrong and how the machine continued to function as usual, but they did not have an answer for that :)
thanks again for your valuable input on this !!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Hashan Ranatunga sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,635
