I had this issue with two replacement batteries, tried the SMC reset, PRAM reset, etc. One of the two responded for a little bit (24-48 hrs), but then would fall back into the "replace now" status and the laptop would not stayed on under battery power. The other battery never responded and immediately said "replace now".
Working with support, I received a cross ship of a third battery and it has worked flawlessly - no SMC reset, no PRAM reset, just replaced and powered up and works great.
So, my suggestion is report the issue back to support and get a second (third, fourth...?) sent out to you. Can't say why, but seems there is some percentage of bad apples in the mix.
Note that I used coconutBattery to document the battery situation with replacement #1 & #2 for support. Gives a series of good data points that demonstrates the status with notation of the battery production dates and cycles. When you think you have a good battery, though, make sure you use it for longer than a couple of days before you call it a victory.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
6
2 Comments
my MacBook is new and I just got it yesterday on July 6 2017. When I opened my new MacBook it says replace now. its new, why is my battery asking me to replace my battery???
preti tarafından
Same happened to me. I unboxed it and now I have the same problem. It says Replace battery and wont charge. Macbook pro 2019 ??? btw did u get ur fixed? Please let me know
Sabin Kchettri tarafından
