Ana içeriğe geç
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
Can the charger unit of the phone be repaired
the metal part of the charger in the phone has come out.I need to know if it can be repaired or does it have to be replaced.is there an ifixit guide for the breakdown of the blackberry curve 8520 and a guide for the replacement or repair of the charger
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
paul murray, Here is a decent video and here are some good instructions to work on your phone. There are some great guides right here for you to follow. It is a repair that requires good soldering skills and a small soldering tip. You will have to de-solder the old connector and re-solder a new one. Check on here for a similar repair. The port is available at multiple places like this. If you need more visual instructions check on here.Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
paul murray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 449
