Ana içeriğe geç
The Kindle 4 has 4 models released September 28, 2011.
Can you fix a broken page turn button?
The page turn button on the right side of my Kindle is busted - when I press it, nothing happens. The other one works fine. Does anyone know a way to fix the page turn button?
Bu iyi bir soru mu?
Puan 1
3 Yorum
Does it works when you press it a little harder ?
tarafından
No, it does not.
tarafından
i have the same issue. by mistake i pushed the button too hard to remove the back case, now it has lost reflex and is slightly out of the frame. i have to push it a little harder than usual for it to work. can i fix this manually without replacing the button ?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
One possible cause is a damaged or shorting ribbon cable. While repairing my Kindle's power button, I accidentally damaged the narrow flexible ribbon on the right side. Two of the four copper traces were torn and I discovered two of the page turn buttons don't work anymore. I may try to replace the ribbon and see if it solves the problem.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yes! I had this same problem and replaced the cable. This is what you do--
-get a replacement cable from ebay or remove it from a "parts only" Kindle
-remove the back of the malfunctioning Kindle, detach the battery, and unscrew the three little screws holding the buttons in place.
-Wriggle the buttons out. It's one unit.
-You can now see the cable snaking through the frame and up into the button well. Remove the broken cable. It's stuck down with adhesive so dental floss can be used to loosen it.
-Pull the broken one out and thread the new one in. Wriggle the buttons back in and replace the screws.
-This is delicate work so you will need tweezers and tiny little screwdrivers. It took me about two hours but my Kindle is now turning pages like a new one! (It's a D01100).
tarafından
Yorum Ekle
En Yararlı Yanıt
Replace the logic board or if there is one, the button board.
Puan 1
1 Yorum:
That is not necessary. Most likely it just needs a new button cable.
tarafından
Yorum Ekle
Yanıtını ekle
Dina E sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 53
Her zaman: 4,210
