Can I make my 2.0 keyboard backlit like a 2.4?
I have a MacBook Unibody 2.0 and wanted to know if I can make the keyboard backlit like the MacBook Unibody 2.4 is?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes you can! but YOU DONT NEED TO REPLACE THE UPPER CASE! All you have to do is buy any 13" MacBook Pro keyboard or a late 2008 aluminum MacBook unibody keyboard (backlit model is 2.4GHz) and follow the topcase replacement instructions and while it is apart, remove the keyboard from the underside with very small screws and replace, and viloa! backlit keyboard! (dont forget to plug in the backlight ribbon cable next to the main keyboard ribbon cable to get the backlight functionality!)
Hope this answers your question and saves you some money!
Bu yanıt yardımcı oldu mu?
Please provide support on how this can be done.
I'm working on making a guide to do this repair/upgrade. It should be done b4 thurday or friday night...
is it still possible to have a backlight keyboard, even if theres no socket installed?
Extra extra read about it!!!
If you just want to add a backlit just follow the teardown steps. Once you done the teardown your only adding two more steps.
Step 1 you'll be seeing the back of the keyboard which is cover in a black film seal with some adhesive. well there a black bracket on the center of it which supports the superdrive and the logic board. Now to remove it there's only two screws one on top and one on bottom of the bracket.
Step 2 remove the black film carefully, the edges are the only ones with adhesive. Once that's done you'll see a clear plastic underneath that is the keyboard component, but you don't have touch any of that in less your planning to replace the keyboard. If so, follow the next flew Steps***.
Now to install the backlit it replaces the black film. Make sure that the backlit ribbon is to the right of the keyboard ribbon, which is going to be the way you'll connect them to the logic board.
Also make sure you press down on the adhesive edges, that's the last defense you have from a water spill.
Then reassemble your MB/MBP.
If you just want a backlit for A1278 you could find it on eBay or even here on ifixit. Or even if your planning to replace both the keyboard and back lit.
Good luck with that.
***Step 3 Remove the clear plastic set it aside with the black film.
Step 4 There's going to be 6 row of 8 screws each that you'll have to remove. Be careful, if you strip one you'll have to drill the head off so you could remove keyboard. So when doing this Step take your time and use the correct screw driver phil#00.
Step 5 On the top left corner the power buttom ribbon there. You'll have to remove two screws.
Once you've done that, you could lift the keyboard out and replace it. Make sure that you put the clear plastic back. Instead of putting the black film back the backlit will replace that. Do make sure that you press down on that adhesive strip. That's your last defense encase of a water spill. Now reassemble the MB/MBP.
Hi, Nathanael, just wondering if you had finished the guide on how to replace the keyboard because I'm thinking I want to save some cash and just buy the keyboard. Do I need the film too, or just the keyboard?
No I havent finished the guide yet... I have been really busy making money enough to pay the bills... everything else is kinda on hold... =( I have it written out essentially but I have yet to get good pictures and upload them etc... Hopefully I'll have some time this next weekend
And yes, you need a keyboard AND the film that goes with it...
91 screws in total - I counted them when upgrading my 2.0 w. a backlit keyboard I bought off of ebay :)
only you need is the backlight pack 30$ on web go dont waste your money brainrulez
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 7,553
