Ana içeriğe geç
12 inç ekranlı PowerBook G4 Aluminum dizüstü bilgisayarlar. 2003 yılında Apple tarafından piyasaya sürüldü.
Why is the screen dim?
I just took it apart to remove a loose screw in the optical drive and now the screen is dim...did I disconnect something? I am also having trouble getting the keys back on (is it a coincidence that one of the keys I removed was the dimmer key and the other is the brightener key)
Bu iyi bir soru mu?
Puan 1
4 Yorum
are you saying that you cannot increase brightness because the key is not working?
tarafından
Thanks for the tips, I tried an external keyboard and proved that the problem is not the keyboard. I think I might have tweaked the display cable when I was putting the computer back together or maybe I mixed up some of the screws, could a too long or too short screw cause a problem?
tarafından
DEAR LEMERISE..THE screen is very dark...if I turn it at a particular angle I can see the icons,etc on the screen.
tarafından
12"...I've ordered a new display cable and when I get it i'll recheck all of my screws to make sure they are the right ones in the right places..thanks for your advise
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may go to the system preferences display preferences and check if you can modify the brightness from there. If yes then the keyboard has a problem. Try with an external USB keyboard.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
try turning up the brightness, also charge your battery, the screen dims when the battery lowers, you could try to check the display cable too.
Puan 0
Yorum Ekle
What is the PowerBook model (speed) ? 12"/15"/17" ?
Puan 0
Yorum Ekle
You still have video in the screen so the new display cable will not solve the problem. From your description it seems to be a lightning problem related to the inverter cable, inverter board or backlight. You say the screen is dim. Is it completely black or there's still light in it ?
Puan 0
Yorum Ekle
If the long screw you are referring to pinches a cable it can cause problems.
only YOU can tell if you put it together properly - why not take it apart and check - that way you also can check if you damaged a wire by routing it incorrectly.
Puan -1
Yorum Ekle
Yanıtını ekle
oliviachas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 30
Her zaman: 2,768
