Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
MacBook Pro is just dead
My Macbook Pro does not start (boot) anymore, no sign of life at all.
What I tried so far:
1. pressing the power on button in various combinations with the cmd, ctrl and shift buttons (as suggested on some websites)
2. removed the battery, pressed the start button for at least 10 seconds and replaced the battery
3. removed the battery and tried to start without battery (but with the battery charger connected)
Doing a battery check (pushbutton at the left side) rusults is no leds lighting when the battery charger is disconnected and all leds lighting when the battery charger is connected.
Any help is appreciated,
Rik
Bu iyi bir soru mu?
Puan 4
2 Yorum
A history of the machine might help.
tarafından
the macbook worked fine for years, some days ago I left it in working order, when I returned one hour later it was dead.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Knowing the exact year/model would assist us with getting specific info for you.
Check the power adapter voltage with a meter. Perhaps it has failed.
Can you borrow another adapter or charge the battery in another MacBook ?
Bu yanıt yardımcı oldu mu?
Puan 4
25 Yorum:
I tried another adaptor without any result.
The model is A1286, year 2010.
tarafından
Rik. Thanks for accepting my answer but its a little premature if you are not up and running. Now I have the model no ill see if I can't give you more specific advice. Are you willing to put your Mac apart to investigate?
tarafından
Ok, I "unaccepted" the answer.
As long as it can be reversed I am willing to disassemble the Macbook.
Thanks, Rik
tarafından
do you have a multi meter or can you borrow one?
tarafından
yes, I have a multimeter
tarafından
20 tane daha yorum göster
Yorum Ekle
Did your MagSafe only light up with a dim green light?
Mine shows only a dim green light with the battery in or just the AC. The battery lights are all off. Do you think your fix would work in my case?
Puan 3
1 Yorum:
I had no LEDs lighting when running only on battery and all LEDs lighting when running on the AC power supply.
But if you have the screwdrivers, the resistor and a voltmeter at hand it takes less than half an hour to try it.
tarafından
Yorum Ekle
Anyone else in this situation can try this, to verify if the battery is the culprit (on older Mac models with removable battery):
https://osxdaily.com/2019/06/14/how-boot...
Puan 0
Yorum Ekle
Yanıtını ekle
Rik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 3,559
