a dotted line is there on the screen, how to remove it?
a dotted line runs through in the middle of the screen..i don't know if it is a hardware problem or a software one..
Bu iyi bir soru mu?
Bu iyi bir soru mu?
sri hari, attach an external monitor and see if you have the same line. If you do, then it is most likely a software issue. Try all modes of your OS i.e. safe mode etc. If you do not have that line, then you most likely need a new LCD, especially if it is only a single line. this is most often caused by a bad LCD TAB. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 4,238
