Rbrown7784,having scoured the forums over the last few month, the problem is most certainly the micro USB port. You could disassemble your Kindle. Follow this guide. and check the solder connection on the micro USB port. It is very likely that they have either come totally of the board, or that they have micro cracks. It might be possible to reuse the old connector and resolder it, or you may have to find a new connector. If you need a new one, you could check mouser.com or digikey.com for a micro USB that fits the dimensions of your Kindle. There has been one seller on ebay, but they wanted $30 for the port. If anyone would post the exact dimension of the micro USB port, we could try and find an equivalent part. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
