Ana içeriğe geç
Pocket-sized GPS receiver with a 4.3" touchscreen and Bluetooth.
8 Soru Tümünü görüntüle
Back removal to replace battery
I would like to remove the back cover on my Go 720 but have had no luck to date. need help.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
ron, follow the instructions for a battery replacement, they will show you how to disassemble your Go720. Here is a video on it and here are the written instructions. Hope you will take lots of pictures and create a guide for this ;-) Good Luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
when trying to open a device first look for any visible screws, then check and see if screws are hidden (under stickers or rubber feet). to check under stickers without removing the sticker just run your finger or a tool over the sticker and see if you find a round dip where a screw will be.
last will be clips under a frame, use a pry tool to lift the edges till you hear the clips pop and release and work your way around. if you dont have a pry tool you can use a butter knife to a small chisel but i recommend something that hard plastic to not scratch or damage anything.
hope this was helpful, good luck and reply back with your results.
Puan 0
Yorum Ekle
Yanıtını ekle
ron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,198
