Ana içeriğe geç
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
No longer charges, whether on or off
My Logitech H800 wireless headset used to charge when on and in use, or when off and not in use, but now does neither. I have tried using USB from computer, from wall, changing different USB cables, everything I can think of. Where can I get a replacement battery pack for the Logitech H800 wireless headset?
Bu iyi bir soru mu?
Puan 3
11 Yorum
Purchased a replacement battery pack from ebay: NEW Replacement Battery for Logitech H800 Wireless Headset. Now to see if I can install it without breaking any of the connecting wires ...
tarafından
I think you'll Be fine. Just like any repair, take your time and always inspect it first before disassembling :-) If you need help, ifixit answers will be here
tarafından
Mabel Xu,
were you able to fix your H800.
tarafından
replaced battery successfully, but headphones still did not charge ... ended up calling in to claim warranty and get a replacement, their customer service is quite good.
tarafından
I put in the replacement battery pack, but that one soon stopped charging as well :( not sure what components on the boards to test to revive these headhpones, I have 2 pairs, both the same behavior.
tarafından
6 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem most likely is not the battery but the connection between the micro USB and the headset. The micro USB's miniature connectors are probably broken off. That happened to mine. I had to take the headset apart and solder the connecting pin back. You will need a magnifying glass to see it. It is very tiny...
Bu yanıt yardımcı oldu mu?
Puan 7
7 Yorum:
going to assume you cant solder across those pins and have to do each one.
tarafından
My USB port broke completely. Have to replace it. What type of micro-USB port is the correct replacement part? 5pin type B???
tarafından
could you give a really zoomed in picture of what the repaired micro USB socket's connections should look like? thanks
tarafından
I ordered the parts at amazon .. as soon as they are here, the electronics-workshop guys at my workplace will do the soldering. I'm so exited .. You will get your photo, but it may take 2-3 weeks. The socket has 5 pins at its backside .. you should see those. The are SMD-soldered, so don't expect any big conections ..
tarafından
I got the USB-port, the workshop did the soldering. I'm sorry I cannot deliver the Photo, I don't have any camera with a macro objective for THAT small parts. Long story short: It's possible to repair/replace the USB-port but you have to have a lot of practice and/or a lot of knowlegde about soldering. Even the guys at the electronics workshop at the university were waiting for the one single colleague thats experienced in SMD-soldering.
tarafından
2 tane daha yorum göster
Yorum Ekle
Mabel Xu, depends on where you are located. Part number for the battery is 993-000565 and it is available at places like this as well as right here. Hope this helps, good luck.
Puan 2
Yorum Ekle
You can also purchase the replacement battery directly from Logitech here but they ship only in the US.
Puan 0
Yorum Ekle
Yanıtını ekle
Mabel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 55
Her zaman: 38,823
