Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
Intermittent display screen related to angle?
I replaced HD and RAM on my 2006? Macbook 2 GHz Intel Core 2 Duo Memory:4GB 667 MHz DDR2 SDRAM
It has been working fine for 2 months.
Now, the screen will black out-- sleep? but won't display anymore. If I almost close it and slowly open the screen it comes on until it's almost 90 degrees...further opening causes black screen.
Intermittent means loose connection? or something worse?
What do I do to diagnose this problem-decide if I can afford or should attempt to fix it.
Thanks
Bu iyi bir soru mu?
Puan -1
2 Yorum
Yes thank you. I see "DIFFICULT". I read what a splunger was...I think I'm WAY out of my skill set here. Any advice on this part?
tarafından
The guide is good even for a beginner. But it's not an easy fix. Maybe we can get you to a good tech. Where do you live?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You probably have this machine:
Apple MacBook "Core 2 Duo" 2.0 13" (White/06) Specs
Identifiers: Late 2006 - MA700LL/A - MacBook2,1 - A1181 - 2121
I would replace the inverter cables, here's how: MacBook Core 2 Duo Inverter Cable Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
live in the southwestern tip of VT in a rural area. This is NOT apple country. The nearest apple store worth driving to is in Albany 60 miles away. There's a place called Small Dog--just opened in Rutland VT recently--but I need an approximate price of repair--given my limited funds and 06 laptop...
I fear there are no techs in these mtns!
ifixit helped me with the Ram upgrade, and then a HD transplant...I just don't have the overview of what else could go wrong...If it was a car, I'd be askin' if it's more like I'm going for a 'classic car' or is it a loosing proposition?
Is there a different fix (something with an easy rating) that is a more contained component swap (as the HD replacement was) ?
Thanks!
any help will be appreciated!
HAPPY SUMMER!
tarafından
Yorum Ekle
I live in the southwestern tip of VT in a rural area. This is NOT apple country. The nearest apple store worth driving to is in Albany 60 miles away. There's a place called Small Dog--just opened in Rutland VT recently--but I need an approximate price of repair--given my limited funds and 06 laptop...
Thanks!
HAPPY SUMMER!
Puan 0
Yorum Ekle
Yanıtını ekle
georgiaruocco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 145
