Ana içeriğe geç
This Power Mac G4 has Mirrored Drive Doors.
80 Soru Tümünü görüntüle
Soru Kapandı
Video card upgrades available?
I am upgrading my G4 Power Mac MDD dual 1.42 MHz PowerPC (FW 800) that was the first model to have the 800 Fire Wire installed. Apparently, this model is a bit picky about some of the components compatibility. If things aren't just right the computer won't work.
This came with an ATI Radeon 9000 Pro with 64MB of DDR SDRAM video card which has gone belly-up. I not only have to replace it, but I want to upgrade to a faster, better performance card. I have sought the advice of several sources, but most people I have talked to are unfamiliar with this model and their suggestions have all been wrong.
I now have several video cards which I can't use sitting around taking up space. All of them reportedly work on the QuickSilver models, but not on the (FW 800) Model. CAN anyone help me, please???
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sorry to say your in for a bit of work here.
Most of the GPU vendors have moved on with PCIe boards and your system has the old original PCI interface. So your only option here is to look at the used market for a workable board.
I would recommend replacing with the exact same ATI Radeon 9000 Pro you currently have looking on eBay, that would be the easiest. As you are still running an older OS-9 or early OS-X using Rosetta services your upgrade options are very limited here between the drivers and any tech support.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 226
