Ana içeriğe geç
Repair and disassembly guides for Sony DVD players.
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
2 Yorum
Mine takes awhile loading then says can not play this disc.
tarafından
I wanted to know the spray that is used in cleaning of the lens inside the DVD
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
tarafından
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
tarafından
Yorum Ekle
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
Puan 0
Yorum Ekle
Push power protector
Puan 0
1 Yorum:
Push
Reasonpower protector not working
tarafından
Yorum Ekle
Yanıtını ekle
Narni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 13,875
