John Poen, here is the trouble shooting guide from Apple. It should help to narrow it down.
Diagnostic LEDs
The iMac (20-inch 2007) has four built-in diagnostic LEDs on the main logic board that can help you to troubleshoot the computer. The four LEDs are located to the right of the memory slot, under the hard drive data cable.
It may be necessary to carefully remove the hard drive data cable to view the LEDs.
LED #1
Indicates that the trickle voltage from the power supply has been detected by the main • logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
Indicates that the main logic board has detected proper power from the power supply when • the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
Indicates that the computer and the video card are communicating. This LED will be ON • when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be • ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
The Computer Will Not Turn On. The Display Remains Black and There Are No Sounds From the Fans or Drives.
1. Verify the power outlet is good. Plug a different device into the socket to ensure there is power, or plug the iMac into another outlet. Does the iMac power on now?
Yes: Resolved. Bad outlet.
No: Go on to the next step.
2. Check the power cord. Use a known good power cord. Does the iMac power on now?
Yes: Your power cord has failed. Replace the AC power cord.
3. Check the connection of the power cord on both ends. Verify that the power cord is securely plugged into both the AC outlet and back of the computer. Does the iMac power on now?
Yes: You may have a loose fit to your power cord. Replace the AC power cord and test.
4. Follow instructions in the General Information chapter to reset the SMC. Does the iMac power on now?
Yes: Issue resolved.
5. Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer. Does the iMac power on now?
6. Remove the memory access door and front bezel to gain access to the four diagnostic LEDs. See “Diagnostic LEDs” in the General Information chapter for complete instructions on this procedure.
7. Plug the power cord into the iMac and the power cord into the AC outlet. Check to see if LED #1 is On or Off.
LED #1 is On: This indicates that the power supply is getting good power from the AC outlet. Go on to the next step.
LED #1 is Off: This indicates that the computer is not detecting AC power. If both the AC outlet and the power cord are good, replace the AC/DC power supply. If the issue persists, replace the AC line filter.
8. Press the power button. Check to see if LED # 2 comes On, comes on momentarily, or stays Off.
LED # 2 is On: The Power Supply is functioning. Go on to the next step.
LED # 2 comes on momentarily or stays Off: Replace the Power Supply.
9. At this point in the Power On process, you should hear a boot chime and see that LED #1 and #2 are On. Do you hear a boot chime?
Yes: The power systems of the computer are working correctly. See “Troubleshooting No Video” in this chapter.
No: The logic board is not passing the Power-On Self Test (POST). Replace the SDRAM with known-good memory and test. If the issue persists with known-good SDRAM, replace the logic board.
3 Yorum
John Poen, what are the last three digits of your serial number. That will help us to properly identify your computer.
oldturkey03 tarafından
wow. worked for me. I thought I was dead. thank you for the simple fix
Michael Sherrard tarafından
I hаd a similar іѕѕuе with my MacBook.
It was not turning on despite putting it on the charger for days.
I researched and fortunately had to follow thіѕ guide hеrе: https://bit.ly/3dCsixl
This should be helpful hopefully.
Jerry Boston tarafından
