Ana içeriğe geç
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Soru Tümünü görüntüle
no sound comes out
I've just spent a week trying to solve the same problem on my ipod classic (the antiquated version purchased in around 2004 - 80GB). Apparently the software is updated (version 1.3), but no sound from any docking station, itrip, speakers or headphones. You can hear the static of the headphones / speakers being plugged in, but no sound comes out.
Any suggestions?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Bronwyn, first you should tell us if it syncs properly and if you can access your files with music while the iPod is in diskmode. After that you want to place your iPod into diagnostic mode and see if you get any errors (you may get a FW error). If none of that shows any issues, you may have problems with the audio IC. In the case of your iPod I am leaning more toward this problem. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. If you should get sound by doing so, then you only have very few options. One is a new logic board, the other one is to reflow your old logic board. Or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... By now I can verify that this works since I performed a reflow on three of the boards and it solved the problem. The logic board is of course available at ifixit as well." Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Bronwyn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,357
