Ana içeriğe geç
1.83 GHz Core Duo veya 1.83, 2 ya da 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Which superdrive to purchase?
Hi,
I have a late 2006 iMac (17" Intel, 2.0 GHz Core 2 Duo). It has a Matshita UJ-846 combo drive which has been confirmed dead and requires replacement. I believe that's a Panasonic drive (not a Pioneer). Ifixit.com has 2:
12.7 mm PATA 8x SuperDrive (UJ-85J)
12.7 mm PATA 8x SuperDrive (UJ-875)
What is the difference between the two and which one should I buy? They are both the same price, but one of them is out of stock. Please let me know if any further information regarding my computer model is required in order to appropriately answer this question. Thanks in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
To get the correct part, write directly to iFixits parts department and they will direct you as to which on you need. Here's the link: http://www.ifixit.com/Info/contact
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Good advice + Ralph
tarafından
Yorum Ekle
I have the same superdrive model in my 20-inch, late 2006, Intel. 2.16 GHz Core 2 Duo iMac that needs to be replaced. It reads DVDs. Reads and burns CDs. But will not burn a DVD. Jason did you replace yours? If so with which model how is it working for you?
Thanks,
Sid
Puan 1
1 Yorum:
I would bet that after 11 months this issue has been resolved.
tarafından
Yorum Ekle
Yes, the issue was resolved. I just purchased whichever one was in stock and installed it myself. Everything works great now.
Puan 1
Yorum Ekle
There doesn't seem to be much difference, they're different model numbers, but iFixit says both will work with your computer, so it's up to you do decide (one is more costly). Obviously then, if you're in urgent/dire need, then you should get the one that is in stock.
Puan 0
Yorum Ekle
Yanıtını ekle
Jason Morais sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 2,243
