Ana içeriğe geç
How to get the right LCD
Hi, so I have my old MCB A1226 with the serial W875022SXAG (2.6 GHz). Under the extended apple care I had the faulty nVidia replaced, also the SuperDrive, keyboard and hard drive. So I consider it a good machine to get it up and running again. The only question, will all the LCD's that are marked for A1226 work for this? The LCD switches on, but the screen is not working properly. It used to work when I pressed on the right side, but not anymore (check video what happens when I press the right side here: http://youtu.be/c8ChZ0YrXuE). Thanks!
Bu iyi bir soru mu?
Puan -1
1 Yorum
These are the specs of your computer according to your serial number:
2.4 GHz Core 2 Duo (T7700)
Intro Date: June 5, 2007 Disc Date: February 26, 2008
Order No: MA896LL Model No: A1226 (EMC 2136)
Subfamily: Mid/Late 2007, 2.4/2.2GHz* Model ID: MacBookPro3,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Juris, according to the serial number provided by you, this is the display that should fit. Of course, check the compatibility provided by their site.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for the input! I found this in Ebay: http://www.ebay.co.uk/itm/180624551348?r..., looks like a good deal. What do you think?
tarafından
yes it does, make sure that you contact the vendor for compatibility, but the numbers look right. :-)
tarafından
Yorum Ekle
Yanıtını ekle
Juris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 54
