Ana içeriğe geç
eMac, eğitim pazarı için tasarlanmış ve Nisan 2002'de piyasaya sürülmüş, G4 tabanlı hepsi bir arada bir Mac bilgisayardır. CRT ekran kullanan son Mac modeli olup okullara ve diğer kurumlara düşük bir fiyatla satılmıştır.
Can I replace my CD/DVD drive?
My eMac has a broken CD/DVD drive so I am not able to upgrade my operating system, etc. Can I replace it with a new drive and then upgrade it to a current software version?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a link on doing just that. codyduncum is correct in checking what operating systems your eMac will run. No eMac will run Snow Leopard but the newer ones with enough ram will run Leopard. When you get to the site click on eMac disassembly. Ralph
http://www.wilko.com/
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Here is a link to the versions of OS 10 and their requirements so you can tell which OS your computer will run. Ralph
http://www.twistedmac.com/index.php?opti...
tarafından
nice link ;-) +
tarafından
I try to save good information. Note I modified the link to get it to work here. Ralph
tarafından
Yorum Ekle
I had a similar problem with my internal CD/DVD drive. I haven't replaced it yet, but I purchased an external CD/DVD R/RW firewire drive for which I was able to boot the eMac. I solved a majority of my problems.
Puan 1
Yorum Ekle
I have serviced many of these models. The machine is not picky at all as to what you replace it with. Just use a qaulity drive so you wont have to replace it in the future. It take about a half hour or so.
Puan 1
Yorum Ekle
What is worth in 2012 to answer this question... :) I have just replaced the DVD drive in an eMac 1.25GHz.
It was not that difficult to be honest, but takes some time and effort, following carefully a Macworld 2005 article about this very topic.
Puan 1
Yorum Ekle
Another optical drive is not all that would be necessary. Depending on what you are trying to upgrade to, depends on if you have the necessary requirements such as RAM, or processor speed or type. A new optical drive would work, but be careful knowing that might not be the only thing necessary to fix / update to install a new operating system.
Puan 0
Yorum Ekle
Its1/21/18. I just took a hammer to mine. how can I fix it ?
Puan 0
Yorum Ekle
Yanıtını ekle
Kirk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 6,209
