Ana içeriğe geç
Linksys WRT54G (ve varyantları WRT54GS, WRT54GL ve WRTSL54GS), Linksys tarafından üretilen Wi-Fi özellikli bir ev ağ geçididir.
problem with router connection
Dear Sirs,
I have the following problem with Linksys router wtr54gl: after an unsuccessful attempt to install new software, I have no communication with the Internet and can not reset the router to factory settings.
Expect some advice.
Credit: O. Boev
Bu iyi bir soru mu?
Puan 0
1 Yorum
Oghi Boev, when you say "attempt to install new software" are you referring to installing new firmware for your router? How did it fail? How did you try to do it?
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Puan 0
Yorum Ekle
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Puan 0
Yorum Ekle
Yanıtını ekle
Oghi Boev sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 22
Her zaman: 843
