Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
Soru Kapandı
Replaced LCD and glass but the phone wont turn on.
After replacing the shattered glass and the cracked LCD screen, the iPhone had turned on with a white screen. I then proceeded to attempt the restore with itune, but after trying to set up the system recovery mode on the phone the phone does not turn on anymore. when plugged in the computer recognizes the phones memory but there is not activity on the screen.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
IT could also be that the #1 LCD cable isn't plugged into the connector properly, this is the most common assembly fault so check that before you panic :)
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
You probably cut or ripped your display (LCD) panel cable. To remedy this problem you would have to get a new display (iFixit Part No. IF137-001-1). You can make sure that the device actually works by turning the vibrator switch on and off and if you feel any vibration, then the display is the problem, not the phone itself.
Puan 1
Yorum Ekle
I agree with Tetsuo, i just replaced an LCD and the #1 cable just would not hold for anything. So i ended up cutting a very thin slice of a mechanical pencil eraser and placing that on top of the #1 cable. Then i closed the phone back up on top of the eraser and that provided just enough pressure to hold that cable in place. A couple shake tests proved that this was a great makeshift solution. Crafty eh? :D
ckchardin@gmail.com
Puan 1
Yorum Ekle
Ok when u took apart the LCD screen, and put a new one, your number 1 cable came loose. just take it apart and push that number one cable and keep your finger on while closing it. Use a very thin slice of an eraser and put it on the cable. :D
Puan 0
1 Yorum:
thanks for answering a question, we like new members helping out. Please read other answers first and upvote if you agree with an answer already posted. This will stop duplicate responses.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 8,268
