Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
flashing apple logo every 7 seconds
I have an iPhone 3g and it wont turn on and every 7 seconds it will flash the apple logo then turn off.
But wont do anything while not plugged into the computer.
also it is iTunes doesn't pick it up
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
brooke, "wont do anything while not plugged into the computer." Start off by replacing your battery. Here is the guide for it. If it still does that after you replace the battery, make sure that you clean the dock connector with some isopropyl alcohol and a few puffs of compressed air. Check for any bend or broken pins, and you may have to replace that as well. but start with the easy stuff, your battery. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
brooke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 875
