How to repair Kia Spectra 2004 Speedometer?
How do you test and repair the speedometer that has stopped working but the led odometer still displays. what could be the cause?
Bu iyi bir soru mu?
Gregory Peris, just like previously mentioned, it sounds more like a Speed sensor or a Cluster issue to me. If your odometer would be out as well, it might be different. To remove the speed sensor disconnect the coupler, remove the holding bolt and twist the sensor out. straight forward job.
Yorumlar:
usually if the speed sensor is gone the car wont shift it goes into limp mode and you only have 2nd gear and reverse
by Jimfixer
İtibar: 1
Do all the other gauges work? If so then the speedometer cable is probably broken.
Yorumlar:
There is no speedometer cable on this Kia car model, it works electronically via a electrical cable through a speed sensor. Thanks for your kind intentions, Michael ..really appreciate it.
sorry forgot to say , All other gauges are functioning normal, so not able to say if it is a faulty cluster.
İtibar: 1
I replaced both and my speed meter still dies after 3 miles .My rpm has always kept working don't know what to do next
İtibar: 1
I'm having the exact same problem, and have also replaced the speed sensor, but no change. Next thing I'm going to replace is the wiring. Any ideas on how to get a hold of the wiring schematics? Mine is a 06' kia spectra
İtibar: 1
Its a wiring issue if it work when car is cold and dies out after couple min. I replaced ever speed sensor and cluster.
Yorumlar:
I also having the same problem. I replaced both speed sensors and the dash cluster on 2004 kia spectra. Does anyone know if the cluster is not reprogrammed, will it stop the speedometer from working ?
Past 24 Hours: 7
Past 7 Days: 44
Past 30 Days: 176
Her zaman: 21,823
Sounds more like a Speed sensor or a Cluster issue to me. If your odometer would be out as well, it might be different. Does your transmission shift normal? Anything else going on with your Kia?
by oldturkey03
Sorry for delay Mate, Well transmission shifting is normal, the LED odometer reads but shows the same figures as it requires movement of the speedometer. All else is okay with my Kia Spectra 2004.. and thank God for that. I did have a look at the speed sensor mentioned and it is high on the suspect list. I believe you are right here. Thanks.
by Gregory Peris
I have the same problem. Where exactly is the speed sensor located. My Chilton manual does not even mention the speedometer.
by Mike Curry
Tameka can you post this as a seperate question please
by Jimfixer
My speedometer works perfectly in the morning but wont rise again when after being in traffic for some time. how do i solve this.
by Ebenezer Sackey
Show 1 more comment
