Ana içeriğe geç
Operatöre bağlı olarak US730 ve LG730 model numaraları altında bazen LG Snapshot veya Swift L7 olarak da bilinen, LG Optimus L7'nin bir varyasyonu olan LG Splendor adıyla da bilinir.
How Do I install a LG730 LCD Display Screen?
I just replaced my screen on my LG730, now I am waiting for my new LCD screen to arrive. I am wondering, how do I install it? I have a rough idea, but never had to do it before. I spent time on the internet and could not find much. Does anyone have advice?
Bu iyi bir soru mu?
Puan -1
2 Yorum
Well I should have clarified. I Replaced the touch screen, which had a few spider web cracks in it. I also damaged the LCD screen, I do not know how to Take out, and put in the new LCD screen, at least with out damaging anything.
tarafından
Oh nevermind, I did a little tinkering around, and got it all situated, thanks for the help though man, I'll accent your answer.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Zack Borgen, I am a bit confused. You said that you replaced the screen, but now you are wondering how to install it. Did you check my answer from here:"
Take apart the battery cover using notch below
Resim
Take apart the battery and remove screw (12 point)
Resim
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
Resim
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
Resim
3. Remover the Bracket Camera to upper
Resim
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
Resim
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I'll take another look at my LCD, but it does not just come off like the instructions show. So I'm sure I'm reading something wrong
tarafından
Thank you for accepting my answer. If you need to take a look at the manual, let me know. My email address is in my profile.
tarafından
Yorum Ekle
Yanıtını ekle
Zack Borgen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,854
