Ana içeriğe geç
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
Component identification liquid damage
Can anyone help identify these 2 components,(see red circle) the macbook suffered liquid damage and after cleaning i noticed these 2 look burnt, i think they are resistors. Macbook powers up, fans run, but no screen display, or beep on startup
Thanks
Bu iyi bir soru mu?
Puan -1
1 Yorum
I did add images, dont know why they didnt work, will try again
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
syoung6500, I think I located the components. Please check the attached image to make sure those are the ones in question. If they are, then those are two capacitors, C7525 and C7526 respectively. Both are 10UF 10% 16V 0805 X5R-CERM and are available at places like this Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks very much for the quick reply, ive ordered from the link you gave. Im not sure if this will fix it but i thought ive got nothing to lose by trying.
How do you find out which component is which? if you dont mind telling :)
tarafından
:-) Having the right right tools and the right schematics helps a lot:-) It used to be easier when there were no SMD components and all the resistors and caps were color coded. Now you pretty much will need schematic to repair on a board level. Best of luck to you and your repair. Hope you get it fixed. Keep us informed.
tarafından
Yorum Ekle
Yanıtını ekle
syoung6500 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 259
