Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20011 Soru Tümünü görüntüle
my mac book turns on but the screen is black
My mac book turns on but the screen is black does anyone know how to fix this
Bu iyi bir soru mu?
Puan 3
2 Yorum
Did replacing the logic board fix the problem as I have the same issue.
tarafından
DJ, artrec7 accepted QEII's answer, indicating that this answer solved his problem.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is most likely your logic board, but you could try booting from an external source to check.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
how do you boot from an external source and is a logic board expensive to fix
tarafından
you need an external hard drive or similar with a working OS on to boot from. When you turn on the computer hold alt (opt) and select the external one. However, I do think it is the logic board and logic boards are indeed very expensive to replace.
tarafından
Yorum Ekle
Have you checked that the brightness is turned up? I know that sounds really stupid and you probably tried it first thing, but I once called Applecare because my Macbook Pro was booting to a black screen and they just told me to turn up the brightness. I was a certainly embarrassed that I hadn't thought to try it, but relieved that I didn't need a big repair. :D
Puan 1
Yorum Ekle
I know this post it old, but just to help anybody that has similiar issues. More often than not, the problem is the dc-in board not the logic board( alot cheaper to replace than a logic board). How you can tell is if some of the usb ports dont work( use a laser mouse so you can see the bottom of the mouse light up so you knows its working, or if it doesnt light up you know its not working) and if it boots fine to an external monitor.
Puan 0
Yorum Ekle
Yanıtını ekle
artrec7 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 6,114
